Bulletins
Ok, I need someone to spell it out for me. Exactly what is a bulletin? Is it a notice to the dealer that there may be an issue with one thing or another resulting in some form of a recall? How do I find out what bulletins are out there for my truck?
Matt....They are called technical service bulletins.
I don't know of any more free sites to check to see if there are any
on a certain vehicle.
You could check the NHTSA site...............
Alldata.com has them for a fee.............They USED to be free !
...............geo
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
