What Is In The Max Towing Package
I have a 2007 Silverado crew cab. I have the 5.3 liter engine, 410 gearing, locking differential, the HD towing package, skid plates. What else is in the MAX package I don't have. Thanks...........I did the search thing and the only thing I see different is the MAX towing package has the 6.0 engine. I am sure there is more.........
Besides the stuff you have
It has a super duty transmission
heavier trailering axle
engine oil cooler
6.0
Do you have the classic or the NBS?
engine oil cooler
6.0
I have the New Body Style. Thanks for the reply
From Edmunds:
NHT Max Trailering Pack
Includes Vortec 6.0L SFI V8 engine with Active Fuel Management (displacement on demand), 367 hp @ 5500 rpm and 375 lb-ft of torque @ 4300 rpm, external oil cooler, auxiliary external transmission cooler, heavy-duty 9.5" trailering axle with 4.10 axle ratio, 36mm front sway bar, door badge that reads "Vortec Max", 17" x 7.5" custom aluminum wheels, heavy-duty automatic locking rear differential, 4-wheel disc brakes, trailer hitch platform, electric trailer brake wire harness, 7-wire harness for park lamps, backup lamps, right turn, left turn, electric brake lead, battery and ground, independent fused trailering circuits attached to 7-way sealed connector, 7-way to 4-way trailer adapter, instrument panel jumper wiring harness for electric trailer brake controller, 1-way sealed connector for center high mount brake lamp, high capacity air cleaner and front fog lamps.
From Edmunds:
Cool Thanks. I have most of the things already...........
    250.3k
    Dad X MTB
    Dad X MTB
  • Who's Online   1 Member, 0 Anonymous, 311 Guests (See full list)
