Here she is all finished
silverado man
Heres were the switch got mounted. Its in the steering wheels shadow.
You can somewhat see where I cut the top of the little panel off so I could run the wires.
I had to use a air-file to make the hole that big. You can sort of tell since the hole isnt completely round. Plus the paint I used to cover the bare metal wasnt as glossy.
Yeah, it had pre-drilled holes. But they werent big enough. The top just needed a little filling to get the bolt through. But, the bottom hole was 1inch. I needed it about 2inches.
Nice   :)
The grill guard added alot to the truck
How did the wiring for the lights go.  How hard was it?
Ryan, it really wasnt as hard as I made it to be. I just had one thing go wrong after another. I had a real hard time reading the #'s on the relay and that didnt help. Took me an hour to find out I pluged to wire in on the wrong posts on the relay. But, other then stupid mistakes it was pretty easy.
Jeff, I couldnt mount it to the pop out panel. I had to mount it to the actual dash peice.
