Aftermarket Deck And Airbags
I know its been asked a hundred times....I did a search and came up with mixed comments....but does anyone have proof that the airbags wont go off or go off at random.
I want the harness that gives door chimes and stuff, is this the same one, or do I have to buy a $250 (CAN) one to simulate something with the airbags. I know my buddy's blazer doesn't need one, its an 03 too with the exact same deck.
I don't have proof, but there's absolutely no way the airbags would be routed through a radio that often gets replaced. GM has disabled the ability to turn off the auto-lock feature on doors, do you really think they have the legal fortitude to channel an airbag control through a radio? It's a myth that's propagated by unscrupulous salesmen and installers.
The airbags have no relation at all to the radio. The reason the door chime does is because they're using the system speakers rather than spend the money for another dedicated door chime speaker. That makes sense. The air bag/radio connection makes absolutely no sense, and would have opened them up to lawsuits galore leading up to a recall.
I can't prove to you that astronaughts landed on the moon either, but you'll have to trust me on this one. ;)
yeah my thoughts exactly....thats why I asked.
I could just see so many problems with it if it were true..I know my 04 cavalier was suppose to have this...But I had an aftermarket deck in there for 4 years w/o problems. And the $10 walmart jobby harness to boot.
Thanks man. Just needed someone else to come out and say what I was thinking.
No problem, glad to help. The first time I heard that one, I felt that twinge of panic because I had just replaced a deck. Then reality set in, but they still got me for a moment.
yeah...worst thing was they were selling a nice alpine deck for 179(60% off sale) and than told me I had to buy an adapter for 249 to go with it...I was like F that. I'll stay stock first.
But knowing that others have done it w/o problems...kinda puts the old mind at ease.
Random deploying a/b's would suck a lot.
There is no chance of the airbags malfunctioning if you don't use that adapter. No worries.
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 826 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
