Diablo Predator Tuner U7192 $200.00 Shipped
I have my handheld tuner for sale. I bought HPTuners and no longer need this. It worked great for quick and easy tuning. I got better mpg and better performance over stock. It comes with original box ad instructions. Below is a list of vehicles it works on from the Diablo Sport website.
U7192 Predator Applications:
Gas Vehicles Engine U7192
Chevrolet Silverado, SS4.8L, 5.3L, 6L, 8.1L
Chevrolet Tahoe5.3L, 6L
Chevrolet Suburban5.3L, 6L
Chevrolet Avalanche5.3L, 6L
GMC Sierra4.8L, 5.3L, 6L, 8.1L
GMC Denali, XL6L
GMC Yukon6L
Cadillac Escalade EXT, ESV6L
Hummer H2, SUT6L
Trailblazer (V8)6L
Envoy (V8)6L
YEAR
2006
2007
The eighth (8th) position in the vehicle identification number (VIN) is the code that designates the engine type. The Predator will support the vehicle if the engine code is: 2006 Truck or SUV: 8th digit of the VIN= V, T, Z, B, U, N or G
2007 Truck or SUV: 8th digit of the VIN= B, N,U,T, V or Z
What is the Diablosport Predator?
The Predator is a state-of-the art, high performance tuning flash programmer in a sleek handheld design. Once connected to the vehicle, the Predators internal computer recognizes the vehicles PCM and automatically picks the proper tuning files designed specifically for that PCM. Inside the Predator's memory are the actual tuning files that optimize spark timing and air/fuel ratio curves. The transmission parameters are remapped to improve the shift characteristics such as shift firmness and shift points. Unlike other 'tuners', DiabloSport's programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery. DiabloSport engineers spend many hours on the dyno, street and track to ensure the tunes provided with the Predator are the best they can be.
Dyno Tested Performance Tunes
The Predator was created with one thing in mind, POWER!
Average power gains are in 10-20 RWHP range in the cars and 20-30 RWHP in the truck line. Less for the 87 octane tunes. The Predators additional power makes itself noticeable immediately with an increase in power that starts in the low RPMs and builds into a frenzy at the high RPMs.
A Predator equipped vehicle will notice significant improvements in drivability. The additional power and improved shift patterns created by the Predator tune will yield quicker acceleration and better mileage, whether it is in town or out on the highway.
The power increase in the lower RPMs will yield a better throttle response. The increase in MPG is a byproduct of maximized engine efficiency, the improved timing curve and air/fuel ratio creates a more complete combustion, i.e. the engine extracts more power from each molecule of gasoline.
Timing Table 2000-4000rpm (+15/- 20%)
Timing Table 4000-7000rpm (+15/- 20%)
Fuel Table 2000-4000rpm (+/- 20%)
Fuel Table 4000-7000rpm (+/- 20%)
Idle (+ 500rpm / -300rpm)
Speed Limiters (Trucks Only)
Rev Limiters
RPM Shift Points
MPH Up and Downshifts
Shift Timing
Shift Pressure
Cooling Fan ON and OFF temperatures
Re-Calibrate Speedometer for Gear and Tire Size Changes
Torque Management abuse mode time limit ON/OFF
% torque reduction vs. RPM ON/OFF
Upshift torque reduction (all gears) ON/OFF
Adjust for different injector size
Disable P0430 and P0430 codes
Adjust COT enable temperature
Misfire Low rev
Misfire Low cyl
Misfire idle cyl
Enable/disable MPH, set high to disable
Disable P-codes: 0400,0401,0402, 0405, 1404 and 1409
Disable P-codes: 0410, 0412 and 0418
Disable P-codes: 0137, 0138, 0140, 0141, 0157, 0158, 0160 and 0161
Has the tuner been re-flashed or unlocked?
It has been flashed with the most current updates from Diablo, and it is unlocked and ready for a new vehicle.
