New pics of my truck
HillHound
Heres a before and after with the Manik grill guard
Before:
After:
and another:
Here are the cheap mods:
Paco, I dont know where it came from. My dad bought it a few years ago to put in the tool box. So, I just used some of what was left. I'll go look at it after work and let you know the name of the stuff. I saw it in someone truck on here, but forgot whos. MIght be Toms, I dont remember.
I don't remember what it's called, but I bought mine at Advance Auto Parts.  It mentioned something about being a tool box liner on the packaging.  I think I've seen it at Lowe's Paco.
Great Pics!!!
Love that brush guard :thumbs:
We buy that liner stuff bulk in big roles.. All of our vehicles at one point in time had that stuff in there.. Great if you dont want stuff to slide around.. Bad if your dash is covered in armorall or something similar cause it doesnt wanna stay put!
I used some rubber cement that drys clear to hold them down. I had them fly up on me when I was driving down the highway with the windows down. The rubber cement will rub off if I ever want to take them out or replace them.
It took me about an 2 hours to do it myself. Thats minus the trip to the vet for the cats medicine. I could have done it in 1 hour if the instructions were a little better.
That tool tray liner stuff works really well.  My dad had a problem with it when we sold my Silhoutte.  The sun baked foam residue on the dash in places.  I think it is probably easily cleaned up, but we didn't bother (with 206,000 miles on it--the van equaled $500 for a trade in).
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,317 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
