2007 Drop Question
  • 4 weeks later...
I plan on doin this as soon as I get time. My 07 sits way too high out back.
Does anyone know if the trucks without the z85/71 suspensions have blocks? I'd like to use shorter u-bolts to do this (my sawall broke and I don't feel like cutting the factory ones down).
I am thinking about removing the blocks and using shorter U-bolts on my 2007 Sierra Denali. Does anyone know if there are any issues with doing it?
My new body style '07 Silverado crew cab (Z85/2 wd) has them. They're only about 1" thick.
You might have to trim the axle snubbers and you might have to adjust the headlights.
My 07 looked like a cat in heat... with the butt all hiked up in the air.
I did the 2 inch shackles and the rear is still taller... The shackles actually improved my ride. (less stiff) It was an unexpected bonus. I guess lowering the rear transfers some weight to the rear springs.
Going for the block removal next. I'll post something if it creates any new issues.
I ordered the 2" drop shackles for my NBS Sierra Denali Crew Cab. Has anyone done this yet? If so, did you have to add any shims to correct the pinion angle?
As of this morning, I've done two of them (2" shackles) and added shims to neither one. But they were both regular cabs.
I assume that both were regular cab trucks with standard box. In that case my wheel base is 24.5 inchs longer (119 vs 143.5). That makes for big difference in points of the spring and the driveshaft.
Am I over thinking this? After looking at the amount of work, on my back with no impact wrench, I am beginning to wonder if I will do it at this time. icon7.gif
I think you are overthinking it...I've done ex-cabs in the past without doing anything but the shackles...Nary a problem.
You ARE overthinking it big time... 2 inch drop in the rear of a full size truck "ain't rocket science". I've done a bunch of them over the years and never had a single issue. This includes my 07 NBS.
GO FOR IT!
The result is well worth it...
  • 4 weeks later...
Has anyone removed the rear block in the springs to level the NBS silverado out :cool:
I have. I did both 2 inch shackles and removed the blocks and it leveled my truck. Unfortunately it is a SWB so the drive angle was wrong and caused a vibration. I put in 2* shims and the vibration is gone but the rear raised a tad with the shims. I'm assuming the shorter wheelbase of my truck made the angle more critical.
  • 1 month later...
I just got mine in today from Belltech 2" lowering in the rear only $55 and I have done allot of research on this and it is rare that you need shims. But I will tell you after this weekend ; )
the DJM rear lowering kit (3" drop) consists of 2" shackles .. and new U bolts and plates (removing the blocks) to get the 3" drop ... it's what i will eventually be doing to mine ...
  • 1 month later...
old thread but i'm board at hospitle
(NEW BABY) :rollin: 12/7
ok any way here is a pick of belltech 2 inch front spindles and rear shackles/removed block/shock relocation. Roughly a 2/3.25 drop and no vibration issue. Did have to re-align front end.
grats on the new one ...
nice, after ridin around in mine for a day or so i beleive spindles will be my next purchase for it ... and then removing the block in the rear as well ...
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,058 Guests (See full list)
