110 Heat Must Be Getting To Me
No pics?
I saw a riced out Dodge Ram a few weeks ago... complete with a billet fuel door, euro tail lights, and a HUGE fag wing on the tailgate. There was a lot more crap than that, that's just what stood out to me. Some people just don't have any taste.
BTW, check out some of the heaps on this website: http://www.ricecop.com/
no pics....I noticed it at an intersection heading the other direction, then the light turned green just as I was trying to get my phone to get a pic.
This one too had the big wing and a cab visor.
It had to be someone passing through on I-10. Any of the other wierd looking trucks are just cholo'd with mexican plates.
