Squeaky Springs
Try regreasing all the rubber bushings and inspect them to see if they are worn out. It also wouldn't hurt to tighten everything down to spec, including the shackles and u-bolts.
Check the plastic spacers between the leafs to see if they are worn. I also chased a squeaky noise and found a rock had wedged itself between the frame mount and the spring.
bbwb
Hi All,
My leaf springs are squeaking really bad, especially at low speeds. Does anyone know a trick to quiet them down? The most noise seams to be coming from the rear by the shackles.
Thanks! Nick
What's your e-mail I'll send you the TSB for this Pictures included.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   4 Members, 0 Anonymous, 1,036 Guests (See full list)
