Plastic Grille Chrome
Hey all I was looking at my grille today-2001- and notice it still looks good but the fake plastic chrome looks BEAT. Is their anyway to duff it up aliitle? I don't expect a blinding shine but..........
If it's beat up, scratched, dingled, flaky, not much you can do. By "duff" do you really mean "buff"? Just take some good quality chrome polish and a soft cloth, and a bit of effort, that's about it. The outcome will be about as good as it can get.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 986 Guests (See full list)
