Corvette 7.0 In 2500hd?
I am seriously considering doing this. that 6.0 in there now is nice but it is certainly lacking in some areas. when you finally see the title to your truck with your name on it sure makes you wonder exactly what all needs to be upgraded now. Its a 4wd crew cab but would still be nice to have a hot little engine in it.
Anybody know anyone that builds these LS motors?? my main goal here is more power but I really want that annoying tick to go away and I was told that if you built one with any type of aftermarket piston that it wouldnt tick. is that true?
Isn't the LS engine like every other chevy engine....if its not ticking than its not working right? LOL
Even the corvette engine will tick, it has floating wrist pins too. As far as I can see this is probably whats causing piston slap. And your not gonna get any better than forged pistons with titanium rods, which the 7.0 comes with Stock.
You also have to remember that these engines have roller valve trains which is really noisy.
Throw a supercharger on your 6.0, the whine will cover up all the ticking for sure. And you will have one beast of an engine, I don't think you'd be able to keep up with that even if you had a 7.0 in your truck.
What a cheezy-a$$ story, tell me what alterations needed to be done other than needing to make room under the hood for an oil tank. Let's see some under hood pics!
Because of the work involved in putting the 7.0 and trans in there in the first place. You will need to modify your entire drive line.
If its something you wanna do to be the first or be different by all means, it will be an awesome project and no doubt win trophies.
But the 6.0 can make almost as much power as the 7.0 if you rebuild it right, and once you supercharge it you'll be well beyond.
You will have to rebuild your trans, and you will need a new set of gears and axle shafts. and maybe a beefed up drive shaft too, but everything will line up properly without modification or fabrication. It would be a much easier and quicker project.
my $0.02
I could see maybe doing this in a 1500 fun truck but not a HD. The HD has more weight to throw around and that 7L isn't a truck motor. Lots of HP and TQ but at high rpms as compared to a truck motor.
DEWFPO
sounds interesting, but i still vote for the modded 6.0L, buying an LS7 alone will be nearly like $10k right? as a Supercharger will be 60% cheaper
DEWFPO
You need to go to You tube, search 2500hd. there is a guy on there that has pretty much your truck eating up a ram air trans am. Its nice to see 2500hd out screwing with fast cars. Just though you mite like to see that.
DEWFPO
Well yeah, of course it could work.....but why, then there are better platforms to use (like the 1500). Better bang for the buck in that setup.
DEWFPO
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
