Hey there I'm just wondering how to get my clutch to press down all the way. I changed the clutch, along with the pressure plate and the throwout bearing. Now after it's all back installed, I can't get the pedal to press down far enough. It won't even go far enough to let down the switch that allows the truck to start when turning the key. I have to manually push the button down. I think the hydraulic clutch needs to be bled but I don't know how to do that. I have no idea where the bleeder screw is, can anyone give me any ideas.
Thanks, Ernie
Thanks, Ernie
If your pedel is that hard. Then you either don't have the line to the slave cylinder connected correctly, have something blocking the slave cylinder from moving. or misinstalled the clutch assm.
