A/c Add On
i've been truck shopping and found 88 c1500 2wd with a built up 350 in it. however when the motor was redone the a/c was taken out. all thats left is the controlls in the cab. its a reg cab and im looking for a rough idea of how hard it would be to put a new ac setup on and how much it would cost. it needs a bracket and pulley and belt as well. theres no condenser compressor hoses left nothing. it'd be a complete build.
Easiest thing is to find the same or close model year truck in a junk yard and pull the parts you need. Or compare your truck to a similar one and take note of the parts you need and search for them. Good luck - I have a compressor for your truck I will sell for $100. Came off my 1978 big block truck and worked upon removal.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
