Greetings From A Not So New Newbie!
ropie
Well I found this forum back at the begining of 06 when I first bought my truck. Of course, I had to go back to Japan the day I took delivery from the dealer and had no need to really be here. Now I am back and found this place again! I come from a Honda background and am in the Marines stationed in Yuma. It's been a fun ride for the last 4 years. Many wonderful memories.... So yeah, just wanted to say hello!
A pic of my truck is in my sig if ya'll want to take a look. It's an '04 Spiral Gray Metallic Sportside 4.8L ( or stepside.... don't really know GM calls it. I've seen both) that has some slight mods done by Regency Conversions. The grill, red bowtie, an Air Raid intake, Power Aid Throttle body spacer, HyperTech Tuner, Roll pan, Foose Rims, Magnaflow Exhaust with rectangle regency tips, 2 inch drop and regency sport trucks headrests.
Planned mods include:
Bigger Rims
Bed Cover
6.0L SS Engine Swap (maybe....)
SS front Bumber
Black Chrome Grills
Lower Suspension (but not bags...)
Also, I started a forum specifically for owners of silverado's. Take a look some time and join if you want. (it's rather empty cause I'm the only member ;-) ) Silverado-Performance.com
Well that pretty much sums up my intro.
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 519 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
