2003 Ssr Fs
hello everyone, thanks for checking out my SSR....
2003 SSR 1SB pkg.
Slingshot Yellow
Early Model #761
5.3L w/Auto Trans(for those who are unaware of the 03-04 & 05-06 trans opt)
Every option except the Trailer Hitch, which I sold last year.
Mileage.....just over 19,600 miles
Added Goodies: SCT tuner program(recently retuned)....
now has 93...91...89 performance tunes...runs great
NGK TR55 Plugs(just installed)
ADDCO sway bars.....
FlowMaster 50 series muffler....
Amsoil Air Filter....(open air cover)
Mike in AZ Aux fan....
Mike in AZ Air Dam....
Painted Engine cover(yellow)
Factory Wind Suppressor(not installed yet)
Corvette Servo(not installed yet)
Dennis Reinhart tinkless Driveshaft
Doc Dakota's underhood SSR letters (SS in Yellow)
Mobil 1 5W-30 and Mobil 1 filter.(just changed)
Car Cover
Black Mud Flaps(brand new-never installed)
Oiginal SSR Floor Mats
Rubber SSR Floor Mats(now in use)
Brand New Lloyds Floor Mats(never used) Chevrolet Bow Tie
Sirius in dash Receiver New unused(still in package)
I am the second owner, bought in July of '05 w/757 miles...
Average 9,000 miles per year....
Paperwork included: copy of factory invoice....copies of warranty work completed.
and any other paperwork included when I bought the SSR
Extended Warranty: GM extended Warranty included good til Nov '09 or
44,000 miles with a $50 deductible per visit.
Condition of SSR: near perfect condition, there are some minor chips on the
hood, front fender area that can be repaired, just have not
had the time to do, also comes with a pint of Slingshot Yellow
paint mixed from the paint shop, (unopened)
Tires: looks like brand new, no signs of any wear at all. Probably good for
40 to 50,000 miles...
Price: $27,000 w/Extended Warranty included.. If there is a genuine interest in
the SSR, and Price is a concern, I will be open to a serious negotiation
with the buyer, so that we may reach an agreement that everyone
will be satisfied with.
I have been the main driver, never smoked in, garage kept, and covered
at work.
Location & Contact: the SSR is in the Phila area,(Bucks County)
send me a PM or call me @267-987-3962 with any questions
e-mail [email protected]
.thanks for looking................Tom
Pics available upon request......
