Cryo Bedding
Magnumb
Just installed the stage two pakage from Praise Dyno. Bedding instructions were not included. Do cryogenic rotors require the same bedding procedure as regular china iron rotors? I was thinking these require more heat to strat transfering that all important layer.
-Justin
I always understood bedding to be for the pads, not the rotors. Assuming you put new pads on, I would follow standard bedding procedures. If you changed rotors only, I wouldn't do anything special.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
