Tire Size
I have a 2004 C1500 that came with the 235/75R16 and I see an factory option was for 255/70R16. Will this wider tire fit my stock rims for the 235/75R16? I want to make this change because their are alot more tire options in this size. And the wider tire will help improve winter traction a bit more.
Yup plenty of room. See Below.
Stock Tire - 235/75R16
New Tire - 255/70R16
Section Width: 9.25 in 235 mm
Section Width: 10.03 in 255 mm
Overall Diameter: 29.87 in 758.69 mm
Overall Diameter: 30.05 in 763.27 mm
Sidewall Height: 6.93 in 176.02 mm
Sidewall Height: 7.02 in 178.30 mm
Radius: 14.93 in 379.22 mm
Radius: 15.02 in 381.50 mm
Circumference: 93.83 in 2383.2 mm
Circumference: 94.40 in 2397.7 mm
Revs per Mile: 696.3
Revs per Mile: 692.1
Actual Speed: 60 mph 100 km/h
Speedometer1: 59.6 mph 99.3 km/h
Speedometer Difference: - Speedometer Difference: 0.606% too slow
Diameter Difference: - Diameter Difference: 0.6%
Actually a wider tire will provide less traction in the snow and rain. A narrower tire is generally better. My moms truck came factory with a 245/75/16 factory tire and they got better traction then her 285/75/16 and they went with an all terrain tread pattern over the passenger truck tread. In my opinion the wider stance looks a lot better, but doesn't help traction. Just my .02
i went to 255/70 from 235/75/16 on my truck 3 years ago. they look a lot better and the michelins have much more traction than the unsafe at any speed when wet goodyears.
but they will fit and seat properly on my wheels?
They would fit fine. There is actually little real difference in size. 20mm width and about the same height... Almost like not going with a different size. In fact, nobody but you would likely notice.
I'll bet the real difference is the tire maker and not the size - traction wise. I'm sure they look better!
No problems. I put 265/75/16's on before I put the 18's on and there were no issues.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
