Clearance Lights
xGMCx
Don't know if this is in the realm of your ability here as the GM tech or not...
I ordered a 2008 Sierra 1500. I ordered the truck with RPO "TRW: PROVISIONS LAMP, ROOF MOUNTED." I was led to believe that this was the way to go in order to install clearance lights on a 1500 at a later time since they are not available from the factory this way. I know this is an RPO that is included in the Snow Plow Prep Package and is also available seperate from the Snow Plow Prep Pack (as is my case). My question to you is, do you know if this is the same harness or "provision" used for clearance lights on a Sierra 2500, or is this RPO merely for a courtesy light or strobe? Is the provision I have compatible with mounting clearance lights on a 1500?
I have checked with the parts department and they were not much help. I also have reason to believe that the salesman would not know either, thought I would try here. If you cannot answer this question do you know who I may be able to contact or where I could look to find the answer I am looking for?
Thanks for your time.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
