Lifted SportSide!
Dihappy
Henry, that is one sweeeeet truck - do you need a step to get in, that fence looks awfully low next to it. :(
What brand is the visor?
That i dont know.  Do you like it?  Im not really a visor type of person unless its on an old truck :thumbs:
I also have to agree about the visor.......NIX IT! I love those PJ tires!  Any Rubbing? I've read that the PJ tires are true to their size rating (ie: a 36" dia. tire =36"!). Your running just the right combo for these trucks! Hows the ride?....Cops looking at you funny yet?-----Tom
Are those the same wheels as you?  C'mon, that's why you really like it.  It's white, lifted and has the same rims.
That visor could stay or go, who the heck could even see up that high :thumbs:
  • 3 weeks later...
That is a sweet butt truck. I have a brand new 2002 silverado sportside. I want to put flares on it. Some say factory ones off of a fleetside will work? What kind of flares do you have on your truck?
IndigoZ
:( OK, i do like it cuz its White, Pure, and Holy like mine.
And yes those are the same style wheels i have, but i kinda wish i had 10 instead of 8's.
Those PJ tires are kinda sweet too!
But, i DONT like the visor all that much :D
IndigoZ
Indigo,
That not my truck, mines in my sig.
Many people go with Bushwacker flares.
    whenindoubtuseahammer
  • Who's Online   3 Members, 0 Anonymous, 267 Guests (See full list)
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
