High Speed Vibration
kansashuntmaps
I purchased 2000-2500 4x4 sht bed x-cab 6.0 auto highway tires 95,000 mi.
Truck has vibration that starts at 60mph and gets worse as speed increases. At 80 mph sounds as if you are driving on rumble strips on shoulder. Dealer has rebuilt transmission, front dif, rear dif, balanced both drive shafts, replaced CV joints, front wheel bearings, turned rotors, replaced tires & Wheels.
WHATS LEFT?
Truck has been in dealers shop for 2 months. GM says to replace front drive shaft with a new GM Drive shaft. Could this solve the vibration?
Rough guess, Shocks?
Though not as bad as yours; at 95k my ride went to hell until I replaced my shocks.
Sorry, I forgot they did shocks first.
If front drive shaft out and truck is in 4x4 NO VIBRATION!
Balance drive shaft or a different shaft from new truck, vibration is back.
It is the front drive diff, axles or bearings. they have replaced all.
Whats next? GM says get a new front drive shaft NOT a OEM but NEW.
My 03 Yukon had same problem and I went through the same routine with dealer. After 2 new front tires and and alignment I discovered 3 dents on driveshaft near the rear yoke. I pulled the rear driveshaft off had it re-tubed & 2 new u-joints installed , probelm gone. Previous owner appears drove over curb or big rock.
Is there a lift on the truck? Has anyone looked at the front axle shafts? When the dealer installed the drive shave, did they rotate in in different positions?
Not to place blame, but didnt you notice any of this when you test drove the truck before purchasing?
No lift on truck.
Drive shaft is one piece.
Both drive shafts (front and main) have been balanced twice each. Now I am getting a new one.
Yes I did notice the vibration when purchasing the truck. As part of contract "Fix vibration" . All work done to date is on the dealers nickle. Like I said, Good thing is my truck should be new on the bottom. Bad thing is I have not got to drive it for two months. Dealer is really frustrated. The local District Attorney is after them to get it fixed. They gave me a '07 Pontiac G6 to drive while mine has been in the shop last two months. After diving 3/4 ton trucks.........WOW 35 mgp is great! I guess I let them keep throwing parts at it. I offered a trade out about trhee weeks ago but they are too far into it going down a slipperly slope.
I had a similar problem with my 01 1500 ext cab. It turned out to be a bent rim and a horriblr alinement, fixed both and no more vibration in the wheel
Dealer put set tires/rims off new truck. Vibration still exists.
They took those back off, #$!#.
What I meant earlier about the "rotation" was; how the drive shaft was bolted to the flanges. I have seen one removed without the individual marking the alignment and when the shaft was installed it was "out of phase"(Best way I can put it). The truck then had a noticible vibration. The shaft was then rotated 90 degrees with no luck, then 180 degrees. The vibration stopped.
I would most likely put a new shaft on and see the result. If this doesnt solve the problem, I'd look towards the transmission/ Torque converter, since the vibration is only at 60+ mph.
....good luck
DOH!!!!! :D
sorry for the unrelated out of the blue reply with no meaning whatsoever, i just need to reply to 3 posts so I can ask a question......
And you couldn't find a post to add a comment to? What was your question... how to get back to the HondaCivic forum?
Aaahh well.. Just roughin ya up a little. Welcome to the group.
Back on the subject. I think you have a bad outer CV joint (or bent halfshaft) that is throwing the whole rotating mass of one side of the front end out. How's THAT for a theory? I know you say they replaced CV joints... but I would have to see that. Most dealers wouldn't replace expensive parts without knowing they were bad. They probably "checked" them and decided they were ok. It's really hard to visually inspect a CV correctly unless you have a lot of experience with them.
EDIT: Fat fingered keyboard error
They have ruled out Transmission & Torque Convertor.
When front frive shaft is removed from truck and drivin in 4x4, NO vibration.
It has to be Front Drive shaft to front from there.
They have rebuilt and rechecked the front diff.
How can you drive in 4x4 without the front shaft? You mean when you drive around in 2wd?
In 4x4, w/o front shaft off the truck, the transfer case just spinning. Still have rear drive shaft in place and truck is drivable and has no vibration. This eliminates transmission and transfer case from cause of vibration.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,029 Guests (See full list)
