Unplugged Sensor Question?
Bigmike875
I installed the K&N super 77 on my 03 Sierra a few days ago. I pulled the neg. terminal like it said to do, installed the kit, hooked the battery back up, but forgot to plug the mass air sensor back in before I cranked the engine. The truck ran rough for 5 seconds first , then ran fine for 5 seconds before I caught it. I killed the engine, plugged the sensor back in, and took off down the road, but now it seems that Ive lost some of my snap in my shifting. I have the wait4me 93 tune and before it would throw your head back every shift! Did my truck go into some kind of "safe-mode" or something when I cranked it without the sensor? If not do you know what might have happened and how to fix it? Thanks!!
You need to get the code cleared out of the system. The Pcm see that there is something wrong with the mass air flow sensor so it bypasses it and uses other sensors to make up for the mass air flow sensor.
Couldn't you just pull the battery cable again let it rest for 5min and re-connect to clear the code? Or let it clear on its own?
It never did set a code, I killed it fast enough! Figured it out, I reset the computer, now she runs even better than before, and I get to re-teach it :shakehead:
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
