Spark Plug Question
I recently changed the spark plugs in my 2000 z71. It has 147,xxx miles and I figured they were original so it was a past due change. I know OE plugs were ACdelcos but they were a little on the pricey side for me at the moment so I went with autolite platinum's. Will I be regreting this down the road and have to switch plugs before the next scheduled change? Also the plugs that came out of the truck were gapped at either .044 or .045 and the ones i put in were gapped at .060 which is what is on the fan shroud underneath the hood.
I just changed mine in my 04 5.3L using the AC Delcos recommended on their site. They were gapped at .040 from the factory and the site said to leave them as gapped from the "spark plug factory." Check AC Delco's web site.
The .044 gap is for the iridiums GM recommends now on the 5.3. If you use plats keep them at .060. I'm running NGK tr-55 copper plugs @ .060 I'll probably only get 30-35K out of these but they burn exceptionally well and you can't go wrong if they use them on the vette :D
So those are just the regular TR55, not the TR55GP or TR55IX? And did you re-gap them to .060 cuz the parts store im looking at online says .044?
Another ? for ya guys... Do your trucks have a bit of a rough idle? I dont mean a really bad one where its gonna die or something if your not on the gas. I mean just enough to notice it when your in park or at a stop light. Mine had that before I changed the plugs. With the new plugs it seems to have gotten a smidgen worse. However, I did not change the plug wires, could that be a possible cause? Thanks for the help thus far! :P
They came gapped at .060, I checked them before I put them in.
The .044 gap is for the iridiums GM recommends now on the 5.3. If you use plats keep them at .060. I'm running NGK tr-55 copper plugs @ .060 I'll probably only get 30-35K out of these but they burn exceptionally well and you can't go wrong if they use them on the vette :crackup:
Another ? for ya guys... Do your trucks have a bit of a rough idle? I dont mean a really bad one where its gonna die or something if your not on the gas. I mean just enough to notice it when your in park or at a stop light. Mine had that before I changed the plugs. With the new plugs it seems to have gotten a smidgen worse. However, I did not change the plug wires, could that be a possible cause? Thanks for the help thus far! :D
Wires, you gotta change the wires when you change the plugs on these engines. Especially if they are high mileage and 5 to 6 years old. The wires may look great but you likely damaged them internally when you were pulling them off.
Which wires would you recommend? ACdelco or would I be fine with something like autolite's?
Call your local Carquest and get their best.
CARQUEST Auto Parts
920-429-6600
799 POTTS Avenue
Green Bay, WI 54304
3 E
2
CARQUEST Auto Parts
920-468-5333
821 LIME KILN Road
Green Bay, WI 54302
5 SW
3
CARQUEST Auto Parts
920-336-7766
444 Main Avenue
De Pere, WI 54115
15 W
4
Ricks Auto Parts, Inc.
920-833-6144
715 Woodland Plaza
Seymour, WI 54165
16 E
5
BA Performance Parts LLC
920-845-2394
610 Center Drive
Luxemburg, WI 54217
26 N
6
CARQUEST Auto Parts
920-846-2803
125 North Main Street
OCONTO Falls, WI 54154
26 E
7
Bob's Auto Parts
920-388-3024
511 MILWAUKEE St
Kewaunee, WI 54216
27 SW
8
CARQUEST Auto Parts
920-731-7911
282 North LYNNDALE Avenue
Appleton, WI 54914
27 N
9
CARQUEST Auto Parts
920-834-2741
215 Main Street
Oconto, WI 54153
34 SE
10
Two Rivers Automotive
920-794-7313
1615 16th St
Two Rivers, WI 54241
34 SE
11
CARQUEST Auto Parts
920-682-6508
1019 Washington Street
Manitowoc, WI 54220
34 NW
12
CARQUEST Auto Parts
715-526-2162
502 East Green Bay Street
Shawano, WI 54166
36 W
13
CARQUEST Auto Parts
920-982-6000
405 South Pearl Street
New London, WI 54961
38 N
14
CARQUEST Auto Parts
920-897-4016
111 Franklin Avenue
Coleman, WI 54112
38 NE
15
CARQUEST of DOOR COUNTY
920-743-5584
503 South HUDSON Avenue
STURGEON Bay, WI 54235
41 SW
16
CARQUEST Auto Parts
920-233-3910
2875 Jackson Street
Oshkosh, WI 54901
41 S
17
CARQUEST Auto Parts
920-894-7424
630 PARK Avenue
Kiel, WI 53042
45 NE
18
CARQUEST Auto Parts
715-735-6665
2124 Hall Avenue
Marinette, WI 54143
46 NE
19
CARQUEST Auto Parts
906-863-2617
1209 Tenth Avenue
Menominee, MI 49858
Best as in best brand? most expensive?
Uhmm... quality. Most high quality parts usually run a little higher in price, but well worth it. Give them a call they will assist you.
Ironically... the TR55.... the downfall is that you have to replace them frequently (30-35k)
Ouch! I'd much rather go with the standard iridium plugs and not have to mess changing them out so frequently. At least the plugs are fairly easy to get at.
Iridums and platnums have about the same performance, Iridums just last longer under intense heat of lean applications (boost/nitrous).
Copper is a better conductor than either of those so it makes sense they give better performance.
