Oil Change On My Dads Truck. Help
I’m doing my dad a favor and doing an oil change on his 2004 2500HD with the 6.0L. I was wondering if using Mobil 1 is a good idea or waste of money. I have used Mobil 1 on my camaro and love it, but i am not familiar with these trucks.
Thanks for the help
Running a synthetic is always a good idea. I used Mobile 1 for 5-10k miles but changed to Amsoil. Amsoil quieted my valve tapping.
Not a waste of money and can go the extra distance in extended oil drains if you want to go that route as well.
Do a search on here, just type in synthetic oil and there is a ton of reading on it.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
