Central Mo Tuner
If anybody is looking for someone that can tune in person, please post here or pm me. I just got my truck done. I had a wester's 87/91 tune. He said the tune was very good originally for my truck, but they had to much timing, so he adjusted that and the afr and I am now good to go. He is very knowledgeable and I recommend him.
Was it Keith McCord??
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
