Panasonic Overhead Dvd Player
Hi, I got my hands on a panasonic overhead dvd player model # 15136055. I think it came out of a 03 suburban. From what I can gather Brown/white left audio, Black/white audio common, Drk green/white right audio, light green/black vcm class 2 serial data,Black/white ground, orange power. So is that right. Is all I have to do is grd the black and white and put power to the orange to power it up. Just would like to bench test it before installing. Thanks for any info.
Jim
