No Fuel No Spark?
757-A_V_8_R
I have a 1995 1500 with a 305. The truck does no get fuel pressure or ignition. The fuel pump and relay have been tested and cut on when 12v is manually applied to the relay. There is no ignition coming from the coil unless the 4-wire conector is removed from the distibutor. When the connector removed, the spark appears to be strong, and truck will run as long as gas/starter fluid is put into the throttle body. Any suggestions?
Thanks in advance.
you probably have a bad ignition module, it is under the distributer cap... if that goes out it will cause there to be no engine speed reading, and it will cause no spark and no injector pulse, you should have fuel pressure, but the ecm wont be able to pulse the injectors... replace it and check for corrosion on the connector and you should be fine...
    250.3k
    chfkief
    chfkief
  • Who's Online   5 Members, 0 Anonymous, 1,240 Guests (See full list)
