Rims Wheels
17" x 7.5
6 Lug
Are the rims the same for 4 wheel drive as 2 wheel drive? Standard regular truck.
In the old days 4WD had different rims/wheels. Is this true today or are they the same today?
Nope their the same. 6 lug fits universal on 4wd and 2wd. Just gotta watch width, dont get too much wider then original equipment.
What about years? Is the rim the same for old style as new style? Say the 17" rims. Regular ordinary truck.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
