After the Rancho Lift
Finished the lift and added the Pro Comp 315's - What a difference. Waiting for the NFAB Side bars and the Rancho Skid Plate and the Tonno III cover- I will update when the next mods are done.... Let me know what you think so far, be honest and I am totally open to any and all suggestions.
Thanks a bunch.
Click on this link
http://www.picturetrail.com/gallery....mbers=1
Color matched handles intrigues me.... The tires really look great in person. I know they arent mudders, but they do have a 50K mile tread guarantee.... Uh Huh!
So where do I find the handles????
I will update and improve on the pics the next round. Believe it or not it was a cloudy day (the only one this year) when I took the pics :sideways:
-Patrick
Whats the Rancho 4"/6" lift I thought you put on a 4inch lift. What size rims are you running? Can you run 10" wide? Do your tires rub at all? Does the lift really lift it 5.4 inches? I deciding between pro-comp 6 inch and rancho 4 inch
I'm curious about the Rancho 4/6 too??
I E-mailed Rancho about the 4 inch lift.  Their reponse was that it was a 4 inch lift but that many gained additional lift by cranking the T-bars.
The Rancho is the 4", but you do get the 5.4"(with torsion adjustment)- but I opted not to crank the torsion bars at all. I wanted to keep the ride as nice as possible. It comes with the 9000's adjustable shocks which are really sweet. I put the 35" tires on it and we only had to trim the edge off of the plastic that wraps around the bottom of the front bumper. I will snap a couple up close pics. The guy who did the install was amazing. Rancho tells you to cut out the fins on the differential housing but we didnt want to lose the integrity/strength so he cut a section off of the A-Arm and welded a piece back on the side to reinforce it. I have the weld rims and I had to put a 1/4" wheel spacer to get the proper back setting. The rim was rubbing just slightly on the torsion bar. He ground the top edge slightly, repainted it and it turned out sweet. He also cut off the metal piece holding the rubber stop using a sawzall as it cleaned up the whole install and the kit included new ones in a different place. (Sorry for not being too technical) I figure with the 4" (whatever) rancho and the 315 procomps I gained about 8.5". Figure this - A standard garage measures 82" in height.... Going from the stock height of 73.8" (Chevy Specs) to a butt hair under 82" would be 8.2" gain.(I can still get it in the garage) It's plenty trust me.... the kids can barely get in it;-) Math= Tires from 30.5-34.7= 4.2" plus the 4" rancho is the 8.2". Best part is that you keep the ride quality and the tires at 35" fill the wheel wells nicely without any rub. According to ProComp http://www.procomptires.com It has a overall width of 12.5" and a tread width of 10.1". I have 16x7 Weld Racing wheels.
Hope that answers some of the questions. I would highly recommend the kit and will snap some close ups of the work that was done on it.
-Patrick
Patrick, the rig is lookin tough!  I love it.  After I take the body lift off of mine, we'll have twins (of sorts)!
Anyway, I want you to take a closeup pic of that Rancho steering stabilizer!  :lookaround:
And, do you happen to know if the steering stabilizer would interfere with the Rancho skidplate?  I want both items, and want to make sure before I buy em! :thumbs:
So, the 35"s don't rub at ALL now with the front bumper trimming?  I like the way it fills the wheel wells, and I am considering upsizing from the 33"s to 35"s.
All in all, bada$$ rig!  :thumbs:
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 1,214 Guests (See full list)
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
