A/c Blows Cold Regardless Of A/c Switch Position
Hello All,
I have an '03 GMC Sierra 2500 with the 6.0 and 416,280 miles. My air conditioning blows ice cold air even if the a/c button is in the off position. Press the a/c button and the light turns on and off -- but the a/c is on all of the time the fan is in use. I'm aware that the a/c is used in the defrost position, but the a/c remains on in all positions. Does any body know what may be causing this issue? Thank you in advance.
WyoBob
Sounds like your switches most probably, a short of some kind, go to the dealer ask to see the part pop it in see if it works or not. What happens if its on heat? cause I know in my truck and car if you put the temp to hot evenwith ac on it blows hot air...
On a seperate note, How did you start a topic with only 2 posts? and thats some impressive milage.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
