First Road Trip In The Rado
Well this weekend I took a 750 mile road trip from Fort Polk, LA to Kansas City, MO. Then back again. I have an 07 CC Z71 4.8L mini V8 truck w/ 3.42's. I must say it I was impressed by the mileage i got. I cruised at about 70-75MPH and even through the hills of Arkansas I averaged about 20-21 MPG. All I have is Magnaflow dual exhaust. The exhaust drone was not bad at all, couldnt hear it unless I had to down shift. Im wondering though if upgrading my gears from 3.42 to 3.73 or even 4.10 would be worth it. What would a change like this cost (front and back of course) and will 3.73's be worth the hassle? or go straight to 4.10s? Also can I keep my stock rear locker if I upgrade gears? Thanks
What are you looking for going to such a high gear ratio change? Your 20-21MPG will be gone and your RPM's will stay up higher. Unless you are pulling a heavy load or doing a lot of off-roading, you are not gaining anything.
I would like to add a slight lift and some 33" tires one day. I will also be buying a boat or a couple jet skis when I come home from Iraq. Ive the 3.42's suck with larger tires and any towing.
I leave in November. I would love to trade it in a VMAX but I dont know if it would be worth it.
Well, IMO, George "Dubbya" should buy you one....Good Luck over there!!!
Throw in the Bike and I'll trade ya trucks :rollin:
Instead of spending the big bucks on a gear change, spend about the same by dropping a 6.0L in and selling the 4.8.
Power and economy. :rollin:
Power and economy. :cheers:
Uh... wouldn't it just be A LOT cheaper and easier to swap gears?
For me personally, no. Swapping a 4.8 for a 6.0 is super easy. A new LQ9 long block isn't all that much money and most of that could be recouped selling the 4.8. The rest is just a weekend with a socket set and an engine hoist.
4.10 gears will kill any of the fuel economy advantage of the 4.8 which makes the 6.0 an even stronger case.
As a former 6.0 owner and now a 6.2 owner, the root message I'm just trying to get across is there's no replacement for displacement.
Gotcha
    • I think this is the closest I'm going to get to reconciling your statements with my experience.    Can you confirm you haven't measured the amount of oil drained from your engine to verify what quantity was in the engine at time of drain?    For what its worth, the quote above EXACTLY replicates my observations on my 2015, 2016 and 2018, no measurable drop on the stick. EXCEPT that when I measure the oil volume drained from the pan - the drained volume is about a quart less compared to a new fill.
    • A little late to this. I am going to order a 2027 as soon as the order banks open. It'll be a 3.0l again. This time in a Yukon.
    • I know when I was looking around last year to see if someone handled Amsoil gear oil to buy at the retail level which of course means full price. I found an independent shop that works a lot on GM/Duramax pickups and they did not bring in the 75W-85 as they just stuck to the 75W-90 for the front and rear as a standard practice for the HD trucks which makes sense anyway for the higher hp/torque diesel and pulling heavy loads in four wheel drive. I haven't changed my diff oils yet but still plan on using the 75W-85 for the front diff as I highly doubt I will be beating on the truck and figured for my use type the bit thinner oil would be to my benefit for the winter for that slightly less drag. Very different weather here all winter vs northern Washington near the coast, that's for sure.
    • Ok that confirms the extra quart theme they are still going with which must mean they have noted some initial use more so then some engines and probably the bigger factor in all of this probably isn't the engine so much as its the insane distance or OLM that lulls a lot of the driving public into driving their new vehicle off the lot and not even doing one short interval oil change because the manufacturer doesn't say different and if the dealer follows that logic as well. Selling the rarely needing to be serviced concept seems to go over well with the public that wants to get away with as little as possible for dollars spent on the vehicles maintenance and I bet there are 3.0 engines just like other vehicles out there that never have their oil checked by the owner which goes back to why they probably felt the need to add that extra quart to avoid a costly theme.    Speaking of cutting filters open, it was probably over two years ago now that a youtuber who buys vehicles to do longer term reviews and pulls a fifth wheel through the mountains of Colorado on summer trips and that becomes part of the testing. Anyway he had a GM HD with the 6.6 gas and a Ford 250 with the 7.3 gas at the same time and of no surprise the Ford had more power etc but somewhere along the way in the few thousand miles he put on the truck, he changed the oil and was seeing glitter and cut open the filter and yeah, things were not looking spectacular. The truck about that time or soon after seemed down on power compared to what it had been and then threw some engine code, I expect the cam/lifters were failing and so he brought the truck back to the dealer and made some deal to get out of it as he knew it would sit for months waiting on a new engine as they were so backlogged at the time. He kept the GM for some time after that using it exclusively until he sold it after buying his next vehicle to do a review on. Definitely the filter can tell a story when things are starting to go sideways, but it would be a sickening feeling to cut it open and be faced with an ugly mess like that and be running a magnet through the pleats and the oil on the dirty side of the filter and see all the fines sticking to the magnet.    The dealer may have some ideas based on experience as to where that coolant smell is coming from, I would imagine if they can't find it but its smelling they would put dye in it to they could give it a run cycle and use the black light to see where it pops up, if its a hose connection, water pump, rad or even a head gasket etc.
    • Good looking truck, suspensionmaxx looks like a solid option
