Torque Specs
I just bought a Sky Jacker 2" Leveling kit. I need the GM touque specs for the upper A-arm ball joint, outer tie rod, lower strut mounting bolts? And also how many turns down for the headlight ajustments?
Thanks in advance
Mike
I got the torque specs from the GM dealer.
Upper A-arm ball joint ....... 140 FT LBS
Outer tie rod ........ 44 FT LBS
Lower strut mounting bolts ........37 FT LBS
