8.1 Stalling Problem
I HAVE AN 02 2500HD WITH THE 8.1 AND ALLISON THATS STALLS AND WILL NOT START, BUT IT CRANKS. ITS HAPPENED SEVERAL TIMES STARTING IN JAN. 07 THROUGH MARCH, BUT ITS BEEN FINE UNTIL THE OTHER DAY. I INSTALLED A NEW BATTERY IN DEC 06. WHEN IT DIES I'VE HAD TO REMOVE THE KEY AND HIT THE LOCK AND UNLOCK BUTTONS ON THE FOB IN ORDER TO GET IT TO START. I SWAPPED KEYS IN FEB 07. THIS PAST TIME IT HAPPENED HITTING THE FOB BUTTONS DIDN'T WORK, I HAD TO CYCLE THE KEY AND I LEFT IT ON A MINUTE AND IT STARTED. I FOUND THAT 4 OF THE RELAYS IN THE ENGINE FUSE BOX WERE INSTALLED DIFFERENTLY THEN SHOWN ON THE COVER, ONE BEING THE FUEL PUMP RELAY. NOT SURE IF ANYONE OUT THERE HAS SEEN OR HEARD ANYTHING LIKE THIS. ANY HELP WOULD BE GREAT.
Actually myself and others have been through it, and have heard this at least 25 times (no exageration) on here and in every instance it was a faulty crankshaft sensor.
Vernon
THANKS FOR THE REPLY, AFTER DOING A SEARCH HERE ON THE FORUM I FOUND MANY TOPICS ABOUT THIS PROBLEM. WILL TRY A CRANK SENSOR ON MONDAY.THANKS AGAIN
DAVE
  • 2 months later...
DAVE
I put a new crankshaft sensor in my 02 and it fixed the problem. Anyone with a 2001 8.1L there is a recall out for the crankshaft sensor!!
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
