2004 Gmc Sierra Stock Headunit
red10
Anyone know if you can use a PAC AOEM GM24 converter with this stock headunit, it's the non bose . I want to hook up all aftermarket amps and speakers. I know the subs are easy to do, but how would it run the door speakers with an amp and does it sound good with this converter or use the JL cleansweep. Thanks, Ben
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 285 Guests (See full list)
