Anyone Install A Pioneer Avic-z1 Or Z2 Into A 2007 Silverado Nbs?
jdugas
I just purchased the following:
Pioneer Avic-Z2
Dash adapter kit (Scosche)
Onstar (non-bose) adapter (Pac OS-3)
Bluetooth adapter (Pioneer ND-BT1)
Ipod adapter (Pioneer CD-IB100II)
Backup Camera (Yanlab IR CCD Keyhole)
- 20ft video cable + power cable
Steering wheel controls adapter (Pac SWI-X) - to come later after I figure out how to add steering wheel controls for the radio.
Now its time to install it all (hopefully next weekend)... Am I missing any cables/adapters/parts that I may need?
I just took the Avic unit out of its box and looked over the cables and noticed that the line out cables are RCA connectors... how do these hook into the onstar adapter?... do I just treat them like regular speaker outputs and splice them together with the wires from the onstar adapter or are there some adapter cables I need to purchase?
Also, does anyone have any pics/info on where I can find the VSS wire, reverse wire (for backup camera), and the steering wheel controls wiring?
I plan on taking pictures of the whole process and posting a guide here when I am done... so any help would be greatly appreciated and would be very useful to other users on this forum.
Thanks!
  • 1 month later...
Pioneer Avic-Z2
Thanks!
"do I just treat them like regular speaker outputs and splice them together" <-- Don't do this. Use the speaker wires with the AVIC, the RCA plugs are for amps.
"the steering wheel controls wiring?" <-- Use the PAC-SWI=PS it plugs directly into the Pac OS-3
Did you find your VSS wire?
Hey,on the metra GMOS-LAN-01 ones we sell at circuit city have the VSS wire in them already its way easyer that way. i have the pioneer avic d3 in my 07 nnbs it looks clean
    • How did all that extra get added? AI bot!
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
