Replace Water Pump
Okay, my water pump seems to be leaking so I need to replace it. :banghead: First, I have a few questions...
Do I need a special tool to get the fan assembly off the old pump? Once I pull this thing apart, I will have no way to get to the parts store so I want to try to get everything I need beforehand.
I've been reading where often times it's just the gaskets leaking. I can't see the weep hole to verify if that's where the water is coming from. Once I get it off, is there any way to determine whether it was just the gaskets or if the pump is actually bad? As long as the water isn't coming from the weep hole, the pump should be okay, right? It isn't leaking too much...just a fairly steady drip, but it's getting on the belts and squealing like a virgin on prom night!
Lastly, I assume this would be done by removing the fan shroud and going in from the top correct? Or would it be easier from the bottom? Anyone have a play by play for this? I can't seem to find one using the search. A local shop quoted me $400, but I can get a new pump for $100 and do it myself.
Thanks in advance for any help you can offer. :thumbs:
Use a strap wrench to keep the WP pulley from moving when removing the fan clutch.
*****Make sure you use the metal Fel-Pro Gaskets******
If you are planning to keep the vehicle for a few more years, I would be inclined to replace the pump, even if there is no water at the weep hole, since you have to remove it to change the gaskets.
Josh, I would not even consider reusing the pump on a 8 year old vehcle. Get a new pump, not a reman and flush the system while in there. If you have rear heat, be sure and run it while doing the flush. Go back with Dexcool and I would suggest a product called Kool It from Lubegard (part # 96001). It is a wonderful product that will eliminate all chemical electrolysis.
At least the top half of the shroud does have to come off. I would also suggest you take a close look at those belts and hoses while in there.
Hey, I bet I sound like some kind of Parts Salesman. :banghead:
Just add a little more insight to this...Throw the hoses & belts away and start over on a vehicle of this age if you are going into a water pump. When I did this job on my '97 C1500, removed the top-half of the fan shroud. Then, the entire radiator simply lifts out the top (which makes it really easy to flush with a garden hose). Secure a piece of cardboard over the exposed A/C coils, climb in and go at it. One tip, remove the fan from the pump before removing the belt, will keep the shaft from spinning while unscrewing the fan.
On your question about pump-squeel and no leaks, it's just an early warning sign the internal pump bearings are on their way out. Another area for bearing squeel is the idler pully and belt tentioner pully bearings. They are too cheap to replace to ignore on a job this involved.
Fully agree on the comment about replacing hoses. I STRONGLY recommend you replace them given the age. Hoses age with use AND exposure so even if your truck sits and doesn't get driven much, the hoses still deteriorate over time. Wouldn't it suck if you changed the water pump and blew a hose in the middle of nowhere two weeks later???
Cheap insurance.
Thanks for all the input guys. Anyone know what size wrench is needed to remove the fan? Are the fel pro gaskets available at the local parts store or do I need to order online?
Josh, although I work for CARQUEST and it pains me to do so, I will tell you that most NAPA stores are now carrying Fel Pro and if I am not mistaken, O Reillys does as well. Our gaskets are Victor-Reinz but there seems to be a general concensus that the Water Pump Gaskets on these engines needs to be a Fel Pro. I believe Fel Pro was the first to develop an improved wp gaket for this engine and I would feel that Victor now has an equal quality gasket. I have never had even one complaint on the Victor but I have also heard many people say the Fel Pro is the way to go.
That is the concensus I've gathered from reading here as well. I've done some searches online for the felpro gaskets at AZ and O'Reilly and all I can find are header gaskets. I'll call O'Reilly. I haven't seen a NAPA around here in ages.
My old truck was a 4.3L V-6 so the pumps are different. It's been a several years (and suffering from CRS) but recall using an large Cressent or channel-locks on the fan. This V-6 had a single, large-nut & threaded shaft where it attached to the pump. There was something else odd, maybe an opposite thread direction. It does spin right off once you crack it loose. Remember using some Locktite on the reinstall to be on the safe side.
I just used a 10'' adjustable wrench.
****NOT ENDORSING THIS BRAND -- JUST USING IT FOR THE PICTURE****
I couldn't get the fan pulley to stop spinning even with the belt in place and pushing on the tensioner! I had to put a wrench on one of the pulley bolts and lay it against the next bolt head to have something to push against that wouldn't spin. And once the big nut finally let go, it spun right off.
Well, done deal!
The hardest part (as expected) was getting the fan off. I fought it for about 1/2 hr., with the pulley slipping and turning. I couldn't figure out any way to pry a wrench in there to stop it from turning. Finally, I noticed 4 holes in the WP pulley, so I ran a wire hanger through one of the holes and twisted it around the compressor pulley. Once the hanger caught, the bolt loosened right up. After that it was gravy.
I didn't use the felpro gaskets. Neither AZ or O'Reilly had then in stock so I had to go with the ones that came with the WP. They look just like the felpro gaskets. All in all, not too hard of a job and I saved myself about $270 by doing it myself. :)
Well, done deal!
I didn't use the felpro gaskets. Neither AZ or O'Reilly had then in stock so I had to go with the ones that came with the WP. They look just like the felpro gaskets. All in all, not too hard of a job and I saved myself about $270 by doing it myself. :cheers:
Good job!!.......I will probably replace mine in the near future so its nice to see its n ot that crazy of a job.
    mark2
    mark2
  • Who's Online   6 Members, 0 Anonymous, 623 Guests (See full list)
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
