Stock Stereo
i have a 2001 sierra sle and most of the lights are out on my stock stereo. i can't see the buttons any more when driving at night. i was just wondering if anyone had this problem. i figure the stereos are just junk and i'll have to replace it.
yep your assumption is correct, these radios lights either burn out or the buttons begin to wear off showing the underlying plastic. happened to my dad's 2001 Cavalier, if I can, I will post pictures of the wear....
my four buttons for a/c, re-circ, rear defrost, and the other one are all burnt out and the seek button on the radio is showing the white, cheap plastic beneath it. my passenger heated seat button light is burnt out as is the swictch for the lights as well. 2000 gmc yukon w/ 120,000 miles. i want to know how to atleast replace the 4 burnt out buttons but knowing gm, im sure you will have to remove the dash or something to access those bulbs.
you really cannot replace those bulbs without ripping up your radio and having some soldering skills, if I remember correctly, when a bulb goes out while it is under warranty, the whole unit is taken out and completely replaced, same for the rubbing of the paint off the buttons.
I've got some pictures lying around of my LED replacement process, but It's not too hard if you know how to solder. Or even if you don't buy in bulk and figure it out. Pretty much all my lights were out and after 2 motnhs of procastinating I finally sat down and finished the HVAC in a night. Theres a tutorial on the stereo here. Let me know if you ahve any questions. And the dash is pretty straightforward to take apart, GM did good.
mine didn't wear, they just started going out. at 75k most of the preset lights were out. its pretty lame now in the dark, i guess i'm not the only one.
I just replaced my IPC and the HVAC controller for the same reason, and I work at the dealer!
    bellssn690
    bellssn690
  • Who's Online   5 Members, 0 Anonymous, 718 Guests (See full list)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
