A few things I just added to my interior...
As some of you know I recently cracked the lens on my instrument cluster so I ordered the HD cluster with the trans temp guage to replace the old one.  Obviously those of you with 2500/3500s see this gauge cluster every day but I thought I'd post it for everyone else to see:
Nice feature-I don't know how useful the new guage will be but it sure looks better than the stupid blank spot on the old one.  In case anyone wonders-the trans temp on my 1500 stays just under 150 degrees unloaded.  I just put it on yesterday so I didn't get to tow anything yet.  I think it's strange that you just plug the new guage cluster in and the trans temp guage works fine.  Makes me wonder why GM doesn't just go ahead and put it on all their trucks.   Here's a lousy photo of the new switch I put in beside the airbag keyswitch:
Haven't had time to wire it up yet but I hope to buy a lighted visor and use the aux switch to turn the visor lights on/off.  Another good way to use some of the wasted spots GM likes to put on trucks.  Anybody have any thoughts on what to do with the 2 pods above the 2 switches??
:idontgetit:
That looks good.
Ask Tom, he'll have plenty of ideas of what to do with those extra pods, I'm sure.  He put a swith in there on his to override the Auto Headlights.
Looks good Ron.  Who did the milage swap for you?  Dealer?  I keep meaning to ask my dealer if they can do that, or know where to send it off to do it, but I keep forgetting.
Yeah, I have the R&D Auto Headlight Override Switch in the spot to the left of the Airbag switch.  You could add some additional back up lights, and put a switch there to turn them on when your not in reverse.  It would help when hooking up your utility trailer at night.  (I think you may have been woking on that idea already.)  Or just put a coule small rocker switches there for future use.  A bowtie decal couel go there, or a Z71 emblem from the Tahoe/Suburban, not sure if it would fit though.  That emblem is 4 inches wide x 1 5/8 inches high.  :D
Thanks Tom.  I didn't swap the mileage.  The service manager told me they have to send the clusters to a shop in Indiana for odometer service.  As far as I could tell, noone does it locally.  Anyway he told me it would not cause any warranty or service problems as long as I disclose the actual mileage when I have service done or sell the truck.  I got that plastic sticker to put on the door with the old mileage and date of change.  I'm not too concerned about it since I plan to keep the truck for a long time.
Yes I did think about hooking up a utility light under the rear bumper.  Seems like it would be fairly easy.  Thanks for the ideas. :D
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
    • I had an alternator fail that was shorted internally in such a direct fashion in addition to the larger gauge cables that it appeared like a VERY dead battery. Granted I think the car did power up, it definitely wouldn't start.   Rodent damage to wiring?
    • ... I don't think he could.
    • Using experience to justify bad advice is lazy and typical of someone incapable of articulating why their advice is prudent.    This immediately sets off the BS alert and the advice that followed certainly qualified.   Asking an idiot for help getting out of dumb situations because he is an expert... at getting himself into dumb situations.   Unless I've been living in an alternate universe - the first thing everyone does when getting into a sticky situation is shift to a higher gear 🤨.   Of course not, the torque multiplication, mechanical advantage and finer control typically afforded by the lower gear is far better suited for this scenario.   There ARE scenarios where a higher gear MIGHT be appropriate determined more by the drivers ability to control EXCESSIVE wheel spin versus applying torque to the ground.
    • I'm not sure I agree with "extreme" low speed, high torque sentiment here with regards to the prescribed use of low range. How about...whenever it's needed?   A 2.72:1 transfer case and whatever differential gears these Silverados have (3.42's, maybe?) aren't producing "extremely" low crawl speeds. Or insanely high torque multiplication. Even with the 1st gear in these newer transmissions. But it does provide mechanical advantage and potentially better control at slower speeds. And with extra weight or towing, I think it adds mechanical sympathy for the truck as well.   Plus, traction control and the other assists generally turn off when you shift into low range. Those aren't needed here, they'll work against you if you need wheel spin. In high range you'll need to figure out how to turn off the various modes those assists provide. Depending on the vehicle, those things don't all automatically turn off or turn completely off.   While I agree that a farmer might have some great practical experience, a recommendation to "always" using one gear isn't very informed advice. If the farmer had said WHY and could explain the physics behind his prescriptive "always" I'd definitely listen. The way he's described here makes it sounds like he could either be uninformed or is telling everyone what worked for him, not necessarily that there could be a more advantageous way about things.
