External Hard Drive
Radon
Currently I have my iPod running through my pioneer head unit, and all that is fine. But here recently my music collection has surpassed my 30 gig limit and I want to know how to put an external hard drive in my truck. I know it's been done I just cant seem to find any help online. Can anyone here help?
Somebody posted a topic about this not too long ago, let me see if I can find it. They used a Pioneer DEH-P6900UB with a USB hard drive.
If you dont have one of the pioneer head units with the dedicated usb hook ups built in, I read somewhere that the add-on usb module from pioneer sucks. Not sure if it is slow or what the problem is, but people say that the ipod hookup is alot better. I personally dont own an ipod, but am thinking about getting one for the sole purpose of adding it to a pioneer nav when i get it.
Don't they make an ipod that is like 80 gig now? that might be your best bet to sell your ipod and buy a bigger one, unless I just totally made up the 80 gig thing. Thought I read that somewhere though.
That would be me :driving:
Why is it better to go with a HDD than a DAP? Because you can load it, install it under the seat and nobody will ever know its there and I don't have to worry about forgetting it at home/work or worry about taking it out of the truck. I'll post pics of my install later.
Check the offical Pioneer Vids:
Connecting a Hard Drive to the DEH-P6900UB/ DEH-P690UB
USB Compatibility on the DEH-P6900UB
That HDD he's using in the video is the same one I have in my wife's blazer. I was using it until I bought her radio, then I gave it to her and got newer one for myself.
I have the Premier DEH-690UB, my wife has Pioneer DEH-6900UB.
I love it, the only thing that gets me is why Pioneer did not include the USB as a standard function on some of the higher-er Premier units?!?! I'd much rather have this feature than BT but that's just me. And yes, you can add BT to the 6900.
+1 for the USB to HDD. You can have 30gigs at your fingertips, and no cds. One thing I heard is that take a External HD and format it for FAT32, which only gives you 30G storage max. My theory would be to take a USB Hub and wire in the power for it, if needed, and run multiple $40 drives at once, it should separate them out, maybe, I don't have the deck or HDs to try it with, worth a shot if your in need of more space, and don't want the 160G iPod. One would definately be enough for me though.
I was under that impression too that it had to be formated to Fat32 but the HDD I have now is a 40gig unformatted. I'm starting to believe it maybe based off of the HDD RPM. The two HDD's I have are 4,200, it probably has something to do with the power needed to supply them. I have yet to try a 100gig. Another thing I noticed is that when I tried a 10ft. usb extension, my drive wouldn't read (again not enough power) so I went back to a 6'ft. cable.
  • 6 months later...
Although this is an old topic, just wanted to post my findings, I used a DC->AC power adapter to install an external 250gb hard drive, filled this hard drive with a 100gb's of music (about 18000 songs) using gentoo linux's fdisk to format the hard drive with a fat partition (not fat32), this allows for a higher than 32gb limit, but then I hit the next limitation, songs per directory, the Deck will only read the first 999 songs in a directory, after that it doesnt show the songs title but still plays them, so fixed that by creating directories ( later found that scrolling through 999 songs was to much so bumped it down to about 300 per directory), ok cool works again, i should mention that my very first run of this contained a format like this: DirectoryA -> SubDirectory A -> Songs and this took over 2 hours for the music to load, ( i do alot of highway driving), so by having a single layer of directories, the songs load in approximatly 45-90 seconds. The limitation ive hit now is that the deck itself stops registering any songs after about 60-70% of the directories so about A-T in an alphabetical list, it displays the directories U-Z but does not let you traverse beneath them, I know having 100gbs (now closer to 200gbs) of music is excessive and an outrageous task to load that many songs for a deck that can now be bought for less than 200 bucks now but i just wanted to show that you can by pass the 32gb limit on hard drives and hit the next one with me.
What deck are you using? I know the Kenwood Nav units are limited to Fat32 (says so in the instructions) and they absolutly (sp?) suck in response time with a loaded 30gig HDD.
Anyone had a problem with the drive bouncing around and writing bad sectors?
Depends on how secure the drive, how it was mounted, and how rough of a ride it has to endure. Personally, I would only use a flash or solid state drive if it's going to be in a vehicle.
A standard notebook drive would work, but you'd need to make sure it was in a good enclosure with rubber or some other type of shock resistant material. Then make sure it's not just sitting in a glove box to bounce around either.
Either you're going to be limited in your capacity or you have lots of money to spend. SSD drives are not cheap, if they were I'd go this route in no time flat.
I've had my HDD drive in my truck since I bought the deck (1.5-2yrs ago I believe) no problems yet but then again I don't run baja either. If you decide to place you HDD in the glove box, use some velcro if you want it will be enough. Me, I bought some hard foam from a fabric store to place my HDD on then I took my cup holder off my jumpseat, cut out the inside channels of the u-beams (length of HDD) and cut slots into the outside channel for some elastic banding to hold the HDD against the bottom of the cup holder.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,253 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
