Intermediate Shaft 2003 Silverado 2500hd
donno1
My truck's steering intermediate shaft was replaced by my Chevrolet dealer at 19255 miles.
The symptoms have apperared again, and are gradulally worsening at 52000 miles.
Shouldn't Chevrolet be responsible for replacing this part even though the warranty has expired? I have heard of many such instances of repetitive failure of this part.
WELOME to the site. dealers have the authority to warranty stuff after the warranty period. they have come up with a new shaft that should solve your problem. my brother just had his replaced in a 2004 yukon xl with 54000 miles no charge. gm knows this has been a problem and seems to be taking care of it.[finally] SO if you talk nice to your servicewriter who knows, good luck :)
The problem may be solved.
I took the truck to the nearest Chevrolet dealer service department and talked to a service rep about it. He looked at the ticket I got when it was fixed before, and said that if the truck only had 52,000 miles on it, they should be able to take care of it! They're going to install a newer revision to the shaft.
I'll schedule next week.
Thanks for the heads-up on the issue.
Welcome. They will probably just re grease it anyway. Common issue.
If it "is" the new shaft, its not an option. It must be replaced.
Make sure they use the correct part,number below.
Subject: Clunking Noise Under Hood and Can Be Felt in Steering Wheel and/or Steering Column (Replace Upper Intermediate Steering Shaft (I-Shaft) Assembly) #00-02-35-003M - (01/31/2007)
Models: 2002-2006 Cadillac Escalade Models
1999-2007 Chevrolet Silverado Models (Classic)
2000-2006 Chevrolet Suburban, Tahoe Models
2002-2006 Chevrolet Avalanche
1999-2007 GMC Sierra Models (Classic)
2000-2006 GMC Yukon, Yukon XL Models
2003-2006 HUMMER H2
Attention: This Service Bulletin DOES NOT include Mid-Size Utilities such as Buick Rainier, Chevrolet TrailBlazer Models, GMC Envoy Models or Oldsmobile Bravada. Refer to Service Bulletin 02-02-35-006A or newer for Mid-Size Utilities.
This bulletin is being revised to update the repair procedure with a permanent fix. Please discard Corporate Bulletin Number 00-02-35-003L (Section 02 -- Steering).
Condition
Some customers may comment on a clunk-type noise coming from under the hood that also can be felt in the steering wheel. These conditions may be more noticeable when turning at low speeds on rough road surfaces.
Diagnostic Tips
Use the information below to help diagnose the source of the noise.
• Frame Snap and/or Popping Type Noise -- A frame snap or popping type noise can be duplicated on rough or smooth road surfaces with steering wheel input to the left or the right. This type of noise can be HEARD and is typically louder with the windows rolled down. For additional information, refer to Corporate Bulletin Number 03-08-61-002F or newer -- Snap/Popping Type Noise Coming from Front of Vehicle (Remove Front Crossmember, Change Fastener Orientation).
• Intermediate Shaft Clunk -- Intermediate shaft clunk is heard and FELT in the steering wheel and/or steering column area, typically while driving on rough road surfaces with steering wheel input.
Correction:
Replace the I-Shaft with P/N 19153614.
Do NOT lubricate or exercise the I-Shaft.
Important:
• I-shaft P/N 19155614 has been designed to replace previous designed dampened and non-dampened I-shafts. The physical difference in the yoke size will accommodate all vehicles listed in this bulletin.
• Due to the design of the new I-shaft, it is not possible to lubricate/grease the I-shaft.
I would like to hear from anyone that has had this shaft installed on their truck ..... I have no problem doing it but would be mad if I did it, and clunking re-appeared!!!!
They need to replace the lower steering bearing as well. The play from the old shaft deformed the plastic bearing, so replacing the shaft without replacing the bearing is like going to the bathroom and not wiping your butt, they have to finish the job.
  • 4 weeks later...
The current information techs are getting says to replace the I-Shaft with P/N 19153614. We are still lubeing them on some cars though.
Never heard of a deformed plastic bearing in the lower steering though.
I have not had a comeback on one of the new style shafts yet, so lets just hope they fixed the issue.
After getting this intermediate shft replaced perDocument ID# 1893252, at no cost to me except frustration, the technician told me that the "Chubaka noise" was coming from the steering column itself. Of course this wasn't a service bullitin that got the intermediate shaft replaced but a document. And the cost to replace the steering column, I don't even want to know. At first one service shop stated that their best mechanic was on the job. After bring the vehicle back, (less than 60 days) and the extended warr. didn't cover the replacement of CV boots (that's what the best mechanic said)which now had a hole in it.....they couldn't find the source of the noise. The inter. shaft was replaced at no cost to me by another service shop....whom stated that the shaft could not be greased! It very annoying but can't come off the cash at this time.... :D
Draenor
Correction:
Important:
well i guess ill be back to the dealer soon had mine done on my 2500 this is part number on the ticket i ask for......
`#19153614.
well i looked up the part number of gmpd and it says 99-07 1500 Fullsize truck upper steering column intermediate shaft... i guess it still work on a 2500hd
Draenor
Correction:
Important:
`#19153614.
this problem is a thorn in GMs behind ,there has been many bulletins ,1st,it was replace,then grease kit,then replace,then,you get the idea,never heard of bearing issue either,the steerng box seal leaks but not alot though,cheers,happy new yr
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
    • There's a bunch of tea leaves that you've read, but in any case the delayed timing is unusual. Not sure how that relates to the rich at idle vs. 'normal' while driving.   If you're in this deep, might be worth investigating, and re-learning the sensor. What have you got to lose? Plus, it properly fixes the timing cover leak.
    • The only problem I have seen this cause is longer crank times.
    • Injector is being sent off today for rebuild and I estimate I'll have it back in 10 days or so.   It may not be the injector...of course...now that I've torn down the intake again. But, let's rule out the injector and replace those spider legs that have been almost rubbed through.   The truck has always had negative timing and I'm reading "normal" timing at warm idle should be +16 or so. I'm negative 16 to 25 or more, and it's always been like that since I bought it.   A light turned on upstairs last night in the old noggin. Rare, I know...   This will be wild, if it turns out to be the cause!   In 2001, according to the old service documentation, the muffler was replaced. Why? I have no idea, it wouldn't have been rusted through by then. But they did a crappy job.   In 2019, another shop replaced it and noted the prior install was poorly done on the work order. "Exhaust system vibrates on crossmember". Except...I guess they just left it be? I believe the husband, the couple who were original owners, had passed by then. Maybe she said it's just not worth it to have the exhaust system fixed and declined repairs. Very few miles were driven between 2019 and 2025.   The exhaust system vibrates heavily on the crossmember and you can feel it and REALLY hear it, even today. Not always, but at idle, it gets going pretty good sometimes.   What if....   ....What if that's enough to trigger one or both of the knock sensors? Could it be tricking the sensors into sensing knock, so it's pulling timing aggressively? Pulling timing heavily means it's firing after the piston reaches full height which means incomplete burn which means the O2 sensor is sensing a rich condition, which means I've been chasing my tail, and what I thought was an inconsequential problem (janky exhaust) has been THE issue for this truck for 25 solid years?   That would be wild. Maybe it IS wild.   The service documentation thereafter, for years, shows visits for rough idle, replacing O2's, replacing the cat, replacing plugs and wires, a misfire condition, like they could never solve the issue. The injector has been replaced 4 times in 80k miles, that's just crazy.   The secondary theory....   The engine has clearly had a leak at the front seal for a very long time (the greasy trench...). I think the truck changed hands quickly ~2025 because there's Napa receipts from someone I don't recognize in the ownership history. They apparently replaced the timing cover seal, and they did a terrible job. There's RTV smeared all over and the leak I had reduced to a weep by snugging the front oil pan bolts is now a leak again.   HOWEVER....I read about replacing the crankshaft position sensor. Any time the ckp sensor is disturbed or timing cover is removed, the truck requires relearning, and that can only be done through a bi-directional scan tool. Skippy with the RTV probably didn't do the relearn procedure is my guess. His scan tool is lost in a pile of RTV goo somewhere.   So, it's very possible the sensor has been disturbed and the truck is just running on the old learn data but not setting a code for anything. The distributor has since been replaced and so has the camshaft position sensor, so all bets are off for that thing.   In the theme of one step forward, two steps back, I returned the accumulator for the AC. The gal I've been working with at O'Really's has been great. She refunded it under manufacturer's defect and we compared it to the replacement I ordered, and sure enough, the replacement is machined very differently (and a gauge actually fits on it!).   Got it home, installed it, started vacuuming it down.... and I couldn't get good vacuum.   The high side service port, where I replaced the old GM ball valve suspecting that was a source of the previous leak....well, I've clearly exposed whatever pre-existing crack in the line where the service port is welded, and made it much worse. Blessing in disguise? Except there goes another $25, now I'm waiting for a replacement AC line.   In 10-ish days ALL the parts will be here. Rebuilt injector, new exhaust system, new cat, new high pressure AC line.   Oh, did I mention the squeaking ISN'T coming from the AC pump? The truck still squeaks when started, and there were words after I started it with the new AC pump installed. But, there was more to replacing the AC pump for just a squeak. A truck with good working AC is something of value, for the comfort alone.   I've ordered a new harmonic balancer because, 30 years is a good run for one of those. Rule it out. The squeak may be something more sinister, though. I'm worried about that ckp sensor and if it was shimmed correctly, or if the timing set was installed correctly. The squeak may be coming from UNDER the timing cover.   At this point, once I get it put back together, I'm thinking I'll take a 50 mile victory lap and then promptly put it up for sale. This truck is cursed. Betty, from beyond the grave, doesn't want anyone messing with her Blazer. Or maybe she's getting revenge for 30 years of shop visits with that thing.
    • 3.59 Kroger’s in Montgomery Tx. 20 cents higher than most around here. Very unusual. Saturday they were 3.49.
