Pre Cut Rear Window Tint-07 Nbs.
I have been unable to find precut rear tint for my truck. I found side tint on ebay but none for the rear. Ive done regular tint before but Im short on time. Anyone know who sells it? Its for an 07 nbs reg cab rear window. Thanks.
Not sure where you are but many tint shops use a tint program and cutter to cut their film now. You could probably just buy a precut back glass piece from them for the same money as Ebay with shipping.
Around here a shop would only charge about 40 bucks to do the back glass for you... PLUS you avoid the hassle and get a warranty.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
