S10 Gear Light Indicator
A friend of mine owns a 2000 S10 2.2L Auto. This problem starting occuring a few months ago and has progressively gotton worse.
The gear indicator light will never show that the truck is in park, you can move the shift where park is supposed to be, but no outline around P will show. The truck will act as if it is in neutral and he has to put his parking brake on whenever he is on an uneven surface. The truck shifts and runs fine, but it will not go into park.
Any ideas?
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
