2004 Suburban Seat Problem
The seat by the right rear door, which can either be folded flat or slid forward to access the 3rd row has stopped sliding forward. This is not a good thing because my 7year old takes it as a license to climb over the seat, troding on the second row and tracking in whatever is on his boots. :confused:
The seat-back still tips forward a bit, when the latch is raised, but it stays at the back end of the tracks. The mechanisms in and under this seat is complicated, there are cables that let the back fold forward without lifting the latch, but only after the bottom cusion is flipped forward, in addition to whatever mechanism is supposed to allow the seat to slide forward if the latch is lifted and the seat back pushed forward.
If anybody else has been down this road before I'm looking for help locating what broke. I'll fix it, but I don't want to put the Sub out of commision for any longer than necessary. Mrs. Kid gets grumpy when she has to use the '93 LeSabre to chauffer the three little Kids. :thumbs:
  • 9 months later...
  • 3 weeks later...
I know this is an old thread but, I'm having the same issue on my 99' Silvy. I had some Upholstery work done on the Driverside seat about a year ago and they adjusted the sliders as it wasn't going all the way back. He said these slides are very finnicky and I should be "easy" with it.
Well, I thought I was being easy with it until the other day it slid all the way back and stayed there. The Seat Slide Rail spat out a piece of plastic and it the seat won't move. I remember the Upholstery shop guy saying it was going to be around a $400 job and that the sliders had to come from the Dealer directly. When I phoned the Dealer on Friday he needed my VIN which I didn't have at the time so I guess I'll phone in on Monday and see what the damage is going to be. Pretty sure it's something I can do I'm just not looking forward to what it's going to cost.
The seats look pretty easy to take out and I'll remember to disconnect the battery before I start anything just in case the Air bag decides it wants to go for a flight.
I'll add to this post perhaps with some pics as i refit the seat and find out more info...
-Evan
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
