Dexcool Confusion
gmc_todd
Hello,
Based on everything I have found, DEX-Cool AF is ORANGE in color. Why is the factory fill AF PINK?
Also, do you know the GM standard the DEXCool needs to meet? For example, oil must meet GM6094M. Is there such a number for the AF too?
Thank You,
Todd
Hello,
Thank You,
Todd
Just use the Prestone Dexcool and you will be just fine.
