2005 Crew Cab Leveling Kit?
All I can seem to find are kits for the 07 model. Do I have to order a crew cab specific kit, Or will any Full size GMC shackle drop kit work? I'd really like to go wirth a 2" shackle rear leveling kit on this truck, but just can't find one.
