Bedliner
I found a bedliner(just the mat) on Amazon for around $100. I cannot select my 08 as an option but says "New body style '07 " i assume this will work on my '08 silverado truck right?
yep it would, so long as it says new body style....
Cool, After a day of reading i figured NBS meant New Body Style. IE: When the new design came out. (i didn't keep up with silverado's)
Thanks. If you're in Houston sometime give a holler, You've helped me enough for a bucket of Bud lights! :thumbs:
Unfortuneatly, it can be even more confusing, because the time before this last body style changed, people called it the NBS. So now, some people call the 2007+ NBS, and many others call it NNBS for new, new body style. NBS can refer to either a GMT800 or GMT900, NNBS refers only to GMT900. Because these are conventions that are used by people, and not specified by any type of authority, I find it easier to just call the 2007+ GMCs and Chevies the GMT900, and the 2007 Classic and earlier the GMT800. Also, the style before the GMT800 is sometimes referred to as OBS for old body style.
Doug
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,164 Guests (See full list)
