Burnt Lights On Wheel Instruments
Some are on some not, can i replace a light or not, i dont want to beak out my tools and take my wheel apart cuz thats nasty its an 05 sierra 1500 non-hd, and one is out on my defogger on my temp control panel, easy fix or no, i searched around and didn't come up with any thing, any help? :lol:
Did you get an extended warranty? If not, then replacing the lamps (or LEDs) on those circuit boards is next to impossible as a DIY project (unless you're an electronics technician.)
Good luck!
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 201 Guests (See full list)
