1970 C20 Ignition Switch Removal
dbajaer
How do I remove the ignition switch? Its located in the dash, tried to unscrew the outer chrome cover, gets a bit loose but seems like there must be something still holding it all together....
there is a small hole in the lock cylinder, turn the key to accessory , take a paper clip and put it in the small hole and depress the button while turning the key to the left. The lock cylinder will then come out and then you can unscrew the cover.
Wow! So easy, thanks Kyle :thumbs:
