Don't Reach Under Your Seat
I was cleaning my truck out today after a long hunting season , I had a few things under it. I reach my hand under the seat and pull out the few papers that were under there and I notice my arm is bleeding :thumbs: , I have like 3 cuts on my arm :D .
So after I reach under there again I feel the front edge of my seat and its razor sharp, about as sharp as a broadhead. I reach under the passenger seat and its the same way .
Next time I go the the dealers, they are going to have to do something about it, maybe file it down or something.
Check the front edge under your seats folks and be careful when reaching under there , if its anything like mine it will slice you up .
Thought I would let everyone know , I'm going to call GM about it and let them know they have a problem there, at least on mine they do.
Anyone else have a sharp edge along their seats underneath ?
i noticed that on mine ... down there ... there is also a peice of the seat cover with a plastic snap trim peice attached to it ... that appears it is supposed to hook onto the leading edge of the metal (what cut me) but i can not get it to stay in place for anything ...
Yes its the leading edge of the seat down there. I never noticed any of the seat cover that should be covering it but I'll check in the morning. I know its pretty darn sharp and gave me 3 1 inch long cuts on my forearm. Maybe I should sue them lol. :D
They need to file it down or come up with some sort of fix, I don't want to get cut everytime I reach under my seat or worse someone else does it and sues me :thumbs:
it appears that the seat covering is supposed to fasten to it ... but from how it is designed ... it doesn't stay in place once you sit down on it ...
it could be ground down to not be as sharp ...
it basically is a peice of stamped metal .. with the rough edge still in plcae ... i just got one nice gash from it when i noticed the seat material being loose ... got it on my list for the next time i make it to the dealership
I know how you feel. When I was installing my seat covers,I was under there and my finger came out bleeding. Nothing like bleeding all over my new seat covers :(
Anyone notice this on the 800s? Haven't been inside a 900 long enough to start poking around under seats n stuff. . .which basically means I haven't been in one for more than 10 seconds.
I never felt it, I just have an LS model so I got the basic cloth manual sliding seats, nothing under there that will cut ya. Just watch out for the corners of the sliding track bars.
Is it something a piece of door edge guard can be installed on? You can get a couple pieces at an auto parts store and cut them to length with a pair of wire cutters.
it's a little bit thicker then a normal door edge .. but that may work ...
It may work but the edge is rolled over so it may be too thick to get the door edge on. I'm gonna take a file to it after I point it out to GM . You shouldn't be getting cut by your truck lol. :D
    Greg3160
    Greg3160
  • Who's Online   2 Members, 0 Anonymous, 505 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
