96 Z-71 Adding Power Windows
I have a 96 GMC Sierra Z-71 SL, it doesn't have power windows or locks, but I can get the door panels and accessories from a junk yard. Is this a easy convert, what do I need off of the junk yard truck, Is the wiring harness already there etc.
Thanks for advice
Matt
You need the whole IP harness and the door harnesses along with the door switches & regulators. You will have to remove the whole dash and change the wireing. Caution, the harness has to be for a exact same truck MY.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
