Intake - Exhaust
I am looking at finally investing in a new air intake system and exhaust system with a PCM. What combinations will work the the best for overall performance? I am looking for a better sound but don't want it to be crazy loud.
I am thinking about bully dog, is that a good brand?
Thanks,
MTmace
2000 Silverado 6.0L
currently all stock setup
There are a ton of combos that work excellent together, it's all about personal preference. For the exhaust the loudest will be Cherry Bomb, Dynomax, and Flowmaster. The more refined exhuasts will be Magnaflow and Corsa. Theres alot of choices for intakes too the most quality ones are Volant, AEM, AFE, and K&N. Alot of people complain about the K&N becuase they think that the oil on the filter will foul your MAF sensor but if oiled properly it will not the only thing K&N skimps on is filtration as their trade off is air flow for filtration but I have one on my other truck and would buy it again. For the chip, I don't know anyone or have never read any reviews on Bully Dogs in a gasser only diesels. Look at Diablo Sport or Superchips, I'd recommend against Hypertech if your going to get a handheld. Alot of people also get the wait4me PCM tune but the only negative downside to that is if you need to have your vehicle serviced at the dealer and they reflash your computer kiss your tune goodbye.
All of what is written above is simply my $.02 and personal opinions
Thanks for your input, especially on the exhaust.
My chevy dealer sells and raves about the bully dog but I have heard more about the superchips.
Thanks,
MTmace
Wait4Me also has a handheld that can hold 3 tunes of your choice. It's like having 3 PCM's.
I am a Flowmaster fanboy, even though I do not run them on my truck, I just went with straight pipes.
As for CAI, I personally enjoy the looks and performance of the AEM Brute Force. I would never go with K&N. I have heard that AFE is pretty top-notch also.
